-   -   Water in bow but not in stern (https://www.offshoreonly.com/forums/general-q/140974-water-bow-but-not-stern.html)
LS1 MOLESTER 09-20-2006 12:38 PM
After i bilge the stern is dry (during planning so i make sure all the water collects in the stern) but in the cuddy there's a small sewer grate and i can see water in there.
Why?
89 Baja 240.
Wally 09-20-2006 02:17 PM
Re: Water in bow but not in stern
the drain hole is probably not close enough to the hull/floor of the boat and all the water cant get out...or its cloged....
Wobble 09-20-2006 03:01 PM
When sitting still in the rain, mine collects water near the bow. I ended up installing another bilge pump for that area, same as many larger boats have anyway.
It should be able to drain to the rear, however when the bulkheads are glassed in there are rough edges that can snag leaves etc.
Sounds like you could remove that grate and get in there with a wet/dry shop vac and dig around.
mats 09-20-2006 04:22 PM
There is a small drain pipe going aft that easily gets clogged. If you remove the "screen" you can get to it and clean it out.
Dave M 09-20-2006 07:02 PM
I had a boat that did that too. I used to suck the water out with a shop vac. The key was to not let water get in in the first place. It usually got in when the boat was not in use. Do you keep it covered?
LS1 MOLESTER 09-22-2006 08:13 AM
Thanks Mats, i will do that next time i'm out. I'll post if it works.
Dave M, i stays covered and no leaks from the cuddy hatch. Sometimes i leave my ice bag over the drain and never worried cause i figured it would drain to the back.. but it's obviously clogged.
