Pics Of Oil Cooler Rigging
Can Any Body Explain Hoew There Oil Coolers Are Set Up And How They Are Ran<plumbed> Etc
Re: Pics Of Oil Cooler Rigging
2 Attachment(s)
This is how I rigged mine up..
How Soon After The Wate Enters The Boat Does It Go Thriugh Your Cooler....first Thing Or After The Sea Strainer
After the strainer..
Make sure you have the direction of the oil flowing exactly as described in the diagram. A fram hp-6 filter has a bypass built into the filter. When the oil is moving faster than the matrix can filter it, it flows through the bypass, which is most of the time. If the filter is plumbed backward the oil will be restricted to the engine and the resulting concequences will be catastrophic. ..... * BOOM *...... :eek:
Now we can start the battle of filter first or cooler first.
My reasoning is filter first. Hotter oil goes thru filter easier, and filter oil goes thru cooler in case motor melts down the cooler will only have clean oil going thru it. If motor is gen VI then also make sure you have the 30 psi bypass in the block instead of the 10-11 psi one |
Very nice job!
We usually plumb filter first as well for the reasone you guys already mentioned.. It's really not much more difficult to do so either.. However if you screw something up bad enough while running, you still will have stuff get into the cooler.. Jamie / Lakeside
i still need to kind of see the route of the water the oiling i now know, thanks for that guys but pics or routing chart would help a lot winter bilge clean up projects
