Garboard Brass Drain Fitting?
I have some bad threads and need to replace the Garboard fitting on the 36 Outlaw.
Went to West Marine and bought one only to learn that mine is larger then the only one they and Boaters World offers and the mounting holes do not match up. The standard is 2 inch flange diameter, mine is 2-3/16 flange diameter. Anyone know who makes or offers the larger size? Many thanks in advance. |
Re: Garboard Brass Drain Fitting?
Can you simply run a NPT tap in a bit deeper to give you some new threads?
Or remove the fitting and have someone braze (weld) a close nipple on to it
| All times are GMT -5. The time now is 04:19 PM. |
