Toe in n Toe out?????
Where exactly do you measure to get the right measurement of a 1/8" in ?thanks in advance.
Re: Toe in n Toe out?????
from what I have seen on this subject, the correct measuring points are from center to center on the nosecones and center to center on the prop shafts
Originally Posted by 88Fountain
What he said. Also, mine are 1/8" toe in and my props spin outward.
Originally Posted by BUIZILLA
1/8 toed in at the shaft end, or cone end?
Originally Posted by docmanrich37
At the cone.
does it matter which prop rotation?
2 Attachment(s)
Just got back from testing my old max machine 1.50s and as i said i lost 10 mph with the bmaxs.Here are a few pics of the garmon gps.I ran 5800 rpms and had a little throttle left.Dustin set the rev limiter to 6400 but i don't want to turn that high.What is a safe rpm at woft can i run ? I was thinking 6000 on the 525's.
Depends on your valve springs and cams...
If anyone needs a slightly used set of bmaxs mine are for sale since they don't work on my set up and since i'm STUCK WITH THEM NOW.I better leave it at that. |
| All times are GMT -5. The time now is 11:25 PM. |
