-   -   Winter Engine Layup (https://www.offshoreonly.com/forums/general-q/142234-winter-engine-layup.html)
Crazyhorse 10-07-2006 04:18 PM
Winter Engine Layup
Does anyone else back the rocker arms off during winter layup?
Just wondered what opinions are on this.
ghittner 10-07-2006 08:39 PM
Re: Winter Engine Layup
Nope, but I do fire it and warm it up from time to time.
cig1988 10-08-2006 06:49 AM
I ususally bump the starter every several weeks. PIA to remove the valve covers.
Vinny P 10-08-2006 06:54 AM
I back mine off every year. I pull all the pushrods to check them for straightness. Also, I check all the spring pressures. IMO, valve train is the most important part of your engine.
Reed Jensen 10-08-2006 01:00 PM
I used to squirt a little engine oil in each cylinder and turn it over a few times. Put in fresh plugs, and fire it up in the spring. No problems.
Elite Marine 10-08-2006 05:19 PM
I've never done it and never had any issues, but it does make alot of sense.
I guess if you can pull your cover off easily, it would be smart.
Reed Jensen 10-08-2006 07:42 PM
Even if the lifters were to bleed down a little... they will pump back up the first time oil gets to them. My concern about letting an engine sit for a long time is corrosion on the cylinder walls from moisture. A tablespoon of oil in each cylinder will take care of that problem for the length of one winter.
minxguy 10-10-2006 11:38 AM
Just make sure the oil get hot to burn off any condensation. 180 degrees plus. Ken
