-   -   Reversion? (https://www.offshoreonly.com/forums/general-q/142775-reversion.html)
djtalon 10-14-2006 06:52 PM
Reversion?
454 420's and after idling i am getting some moisture on plug number 7. If i run with water flowing throu the manifold but not the elbow (dumping into the bilge) plug is dry. If i run water just through the elbow not the maniold i get a wet plug.
Pressure checked the exhaust elbow and cant find any leaks.
Why am i only getting it on one exhaust bank? Exaust is steamy on that bank also . Oil in valve covers is a bit milky.
Mercruiser Gil exhaust
No internal flappers
How do i fix this?
ghittner 10-14-2006 09:04 PM
Re: Reversion?
What cam are you running? What is the centerline?
1CE 10-15-2006 12:31 AM
Re: Reversion?
ck.pressure test elbow again if all other banks are dry elbow must be cracked let us know if your result fairs differently
Stingray69 10-15-2006 11:19 AM
Re: Reversion?
Steamy exhaust means nothing; they can all look steamy, with wet exhaust.
Is the motor coming up to enough temp to vaporize the condensation that is inherant in boat motors?
If in saltwater, could be a corrosion hole in head, ex man or riser,(or are these the SS ones?).
Leathl_WS6 10-15-2006 06:14 PM
Re: Reversion?
My vote is a leaky riser or manifold. Have them pressure checked.
djtalon 10-15-2006 07:25 PM
Re: Reversion?
how or who can pressure check the elbow? I plugged them up and used a garden hose to pressure check them and saw no leaks (more pressure froma garden hose than the engine at idle)
I pretty much narrowed it down to the elbow. When i run with water running through the manifold only i get no wet plug. When i run water throu the elbow only i get a wet plug.
thanks
Griff 10-15-2006 08:58 PM
Re: Reversion?
I'm 99.9% sure its crack in your exhaust manifold. The stock merc Gil's are famous for this when they are 7-10 years old. Water passes through a hose from the manifold to the riser, so a riser gasket is not an issue.
The stock cam will not revert water. Here's the cam.
http://store.summitracing.com/partde...0&autoview=sku
Griff 10-15-2006 09:16 PM
Re: Reversion?
After rereading this I might have to second guess myself.
When you say elbow, do mean the SS riser?????
Is it doing this with the boat in the water???? Everything you said is about it running on a hose. Is the boat sitting at the same attitude/angle as if it was in the water???
If you want ot check the risers, simply switch them from one side to the other and see if the problem follows.
djtalon 10-16-2006 06:29 AM
Re: Reversion?
when i say elbow i mean SS riser.
This is all while it is running on a garden hose, the attitude of the boat is pretty bow up. Not sure if it is sthe same as when the boat is in the water but pretty close. I am guessing the next step is to switch the risers around and see what happens
thanks
BROWNIE 10-16-2006 07:36 AM
Re: Reversion?
A tiny exhaust leak can increase the chances of reversion on one side only.
