Help! Rocker Arm Question for 502 Gen 6 (1998)
Does anyone know if the Magnum roller tip rocker arms (1:7 ratio) from Comp Cams will fit under the stock valve covers without any modifications?
Not sure if I want to grind the drip rail for roller rockers...... |
Re: Help! Rocker Arm Question for 502 Gen 6 (1998)
I had to grid them off for my roller rockers.
I'd keep the stockers over roller tips.
If you upgraded camshaft where rollers are needed I'd spend the money for good full rollers. |
I shoud have mentioned that I run a roller cam and do use full roller rockers.
Are you talking about the gold rockers? Are they junk?
Thanks Shawn |
Not sure if I want to grind the drip rail for roller rockers...... if you hit just buy the fat gaskets or glue two together.... depending on your hoarse power and what ya got going on internally, i would suggest jesel no other rocker assembley compars to them |
I changed from the stock 3/8" and had 7/16" studs put in the heads at a local machine shop. Now the rocker balls do not fit the studs and I have to do something else.
Does the jessel system fit under stock valve covers and without any mods? |
If your cam/springs/pushrods etc,etc is stock Mercruiser, and since you converted to Mark IV style 7/16" rocker studs, you can just buy a set of GMPP rocker arms (come with balls) for the Mark IV BBC.
These should be them: http://www.sdpc2000.com/catalog/523/...er-Arm-Set.htm ====================== Or full roller rockers as discussed. ========================= Shawn - The Crane Gold's are high quality full roller rockers. They are good. He was talking about the 'roller tip' Comp rockers. These still use a ball set up like OE but put a roller tip in this style rocker arm. See pic below of this type. http://www.sdpc2000.com/images/produ...10_4785994.jpg |
OK, thanks to all for the input so far.
I am convinced to go with full roller rockers. What stainless steel roller rockers would be good and fit under the stock cover? It seems some members have had issues with the aluminum ones, although that may be on higher lift applications. (I am running a .527/.544 lift roller cam) Any advice would be greatly appreciated. |
| All times are GMT -5. The time now is 08:57 AM. |
