What size carb do I need.
On my current motor I am using a modified 850 holley that flows about 930+ cfm. Its mounted on a 454 with a 177 blower
If I re jet it would this carb work on a 502 with a 250 blower ??? |
Re: What size carb do I need.
I would sure consider a dual 750 carb setup on that config. But what you have will most likely work, just watch out closely for a lean condition.
1 Attachment(s)
I ran a Nickerson 1050 on my B&M 250/468 CI motor. Dean had it dialed in perfect. You would have no problem selling your 850 carb to a 502 or 540 owner.
When I set up a 509 with 8 71 I ran dual 800's. When I where questioning if it had enough carb. I was told to check for vacuum at the at the top of the blower/ bottom of the carbs. If there is vacuum need more carb.
| All times are GMT -5. The time now is 02:58 PM. |
