-   -   502 ram jet cam (https://www.offshoreonly.com/forums/general-q/143815-502-ram-jet-cam.html)
stevesxm 10-27-2006 02:19 PM
502 ram jet cam
does anyone know for FACT what cam the chevy 502 ram jet pif injected 500 hp crate motor has in it and if it is suitable for marine use ? it uas a 110 centerline... ... i know that much about it...
BY U BOY 10-27-2006 02:37 PM
Re: 502 ram jet cam
Are You Talking About The Zz502/502.
rmbuilder 10-27-2006 02:52 PM
Re: 502 ram jet cam
The Ramjet and the ZZ are the same cam.
224º/234º @ .050"
.527"/.544" valve
110º LSA
BY U BOY 10-27-2006 04:58 PM
Re: 502 ram jet cam
I Am Using That Same Cam With No Problems.
stevesxm 10-27-2006 07:39 PM
Re: 502 ram jet cam
thx... at 8500 seems like a hell of a deal even w/ having to marineize it.
ls1nova 10-27-2006 09:25 PM
Re: 502 ram jet cam
What is involved with marinizing it besides changing the distributor, and adding closed cooling (for the alum. heads)? does it already have stainless exhaust valves?
Thanks,
Frank
jspeeddemon 10-28-2006 10:21 AM
Re: 502 ram jet cam
Yes it does, and the cam will work in some applications but not all, according to what type of wet exhaust, you have. It will work in all dry exhaust systems, such as Lightning, very well. Closed cooling for salt water, opinions vary for fresh water, i have had no trouble running aluminum heads, or anyone else I know in 10 years, and I have owned every major manufacturers set of heads.
SB 10-28-2006 12:37 PM
Re: 502 ram jet cam
I'm definately thinking a bigger + better oil pan is needed.
Also, remember to do the bypass psi valve things to in filter pad. Many threads here on this.
stevesxm 10-29-2006 03:35 AM
Re: 502 ram jet cam
of course all.... my point simply that i was thinking when my 502 mag mpi's time out, just buying acouple of these and swapping out whats nec... just seemed a clean and simple way to go for a solid known commodity thats virtually plug and play... i mean... all new good parts , good power... how can you hate it at that price...
