-   -   Upgrades to 502 MPI's (https://www.offshoreonly.com/forums/general-q/144261-upgrades-502-mpis.html)
dean51267 11-02-2006 08:54 PM
looking to see what is out there that can be done without degrading reliability..... thanks!
the duke 11-02-2006 09:06 PM
Re: Upgrades to 502 MPI's
What are you looking to do? How much do you want to spend? There is a lot that you can do with the pieces in that motor, as they are GM's best stuff, The main restriction on the motor is the stock intake if you choose to leave the motor with its stock efi, unless you put a blower on it. New head gaskets, one whipple and mild boost, and you have just gainned 200+ HorsePower.
Ted G 11-02-2006 09:13 PM
Here ya go, one of the best.
http://www.crockettmarineengines.com/products.html
Just wait till he finishes up jousting with the Duke boyz in Destin before you send the motors over :D :evilb: :D
mats 11-03-2006 05:15 AM
What hp increase will the crockett upgrade yield on a 502 MPI?
Ted G 11-03-2006 07:57 AM
He told me about 100 hp. Basically brings them to between 500 and 525. which frankly is about all you can ask of a stock Bravo anyhow.
satisfactionII 11-03-2006 09:44 AM
And the cost of this HP gain is ?
the duke 11-03-2006 11:05 AM
Site says $6850 plus R&R motor, so in the $7500 range.
Lickitysplit 11-03-2006 07:28 PM
I'm having Derebery Performance Marine rebuild my 502's. Around 500 reliable horsepower. Stock Bravo 1's. Prices are a little above those above.
Bore 0.030" over
Replace ECU
Port and polish the heads, oversize inconel exhaust valves and SS intake valves
New cam
New crane hardware on the head, rockers, springs etc
Aeromotive fuel pump and pressure regulator
First class people and operation. Call Matt: 903-786-3797
Mike
Smarty 11-03-2006 09:04 PM
Bore 0.030" over
Replace ECU
New cam
Mike
What are the cam specs? What exhaust system do you use?
Lickitysplit 11-04-2006 12:24 PM
Smarty, I have no idea yet. We've discussed using the same cam spec'd in the HP 500. I'm headed back up to Texoma next weekend to check on progress. I'll get the details.
I installed Stainless Marine exhaust a couple of years ago. We're going back with that set up.
Mike
Smarty 11-04-2006 04:15 PM
Mike,
Thanks. Has anyone added Gil headers, and what cam change (more aggresive cam) did you have (without the reversion problem)?
Donzi502 11-06-2006 02:41 AM
I have put some E Tops, 230@ 50 and 600 lift cam, had one ground on a 114 blank and installed at 110 centreline. High flow air filter, mild port job and copied Az speeds intake modifications. then just did a very careful build up, all ports matched and just set up nice with lots of care. Marc at Procision marine did the ecu. 495HP at 5500 rpm in a 454 gen VI. Your 502 should pull 520-530 with the same treatment. The big thing is a very carefull and time consuming build up. Make sure you remove the injectors and lube and store. Mine seized and i spent many hours trying to figure out why it wouldnt start. Spend lots on intake manifold and exaust ports. You can half full the intake ports with epoxy and there is no diference in flow. Time the cam perfect with the best chain you can buy with german chain. Quality roller rockers. You need to do a nice job of unshrouding the valves on the bowls. Big wake up there. Now heres the big one. Kendalls 20-50 racing oil only. Good luck with your build. Jason
