-   -   Real cheep and easy Mag air intake (https://www.offshoreonly.com/forums/general-q/144486-real-cheep-easy-mag-air-intake.html)
Donzi502 11-06-2006 01:54 AM
Guys i have just made a replacement flame arrestor out of a block of ABS plastic. Just cut to shape on the dropsaw,6" wide,4" high and 4" long. Drilled it out with 2.5" hole sew on the drill press. Drilled countersunk mounting holes on the drill press. Bolted it on and then screwed a 6" diameter K&N filter plate to the end. Had to bore that out as well and then put the filter on with a hose clip. Works great and flows heaps. Seems to breath better at top end. Whole thing cost $20 plus the filter and took 2 hours to make. Hope this helps some one some day. Jason
twanger 11-06-2006 12:32 PM
Re: Real cheep and easy Mag air intake
Can post some pictures? I was thinking of doing the same.
TylerCrockett 11-06-2006 09:03 PM
Is it Coast Guard Approved ?? The reason I ask is I had a freind of mine made a new flame arrester and had it tested and they actually see how long a fire stays contained in the
arrester.
