2 Pc. Valve Covers >
2 Pc. Valve Covers
2 Pc. Valve Covers
Old 11-07-2006 | 08:47 AM
Default 2 Pc. Valve Covers
Pulled the engine out of the boat a few weeks ago and trial fitted my KE exhaust. I plan to bolt them on next season. With the KE exhaust in place, it looks getting the valve covers off and then back on will be a real pizzer. Would 2 piece valve covers be easier to get off/on ?
If so, can 2 pc. valve covers be had for reasonable $$ and from who/where ? Also, I've heard some 2 pc. covers will leak a little..... that right ?
Recommendations/advice would be appreciated.
Kidnova is offline
Old 11-07-2006 | 08:56 AM
jdnca1's Avatar
Default Re: 2 Pc. Valve Covers
I ran 2 piece on an old motor and loved them. (especially for setting valve lash) They are much easier to get on/off with only (2) thumb screws to deal with. It is true that they can leak a little, but once you get the feel for them and the O-ring to slide in right they don't leak a bit. I think Trick marine sells them or has a version... I'm sure CP has them also.
jdnca1 is offline
Old 11-07-2006 | 10:19 AM
KAAMA's Avatar
I heard they have supposedly fixed the leaking problem on those KE 2-piece valve covers compared to the earlier version. Glenns is using the fixed version on his engines as they're being dyno tested at WESCO....so far NO LEAKS, but I want to see if there are still no leaks as the engines sit in the boat because I would be interested in those valve covers myself. I think they're about $500 per pair and for that kind of $$$ I wouldn't expect that they should be leaking.
KAAMA is offline
Old 11-07-2006 | 06:02 PM
AIR TIME's Avatar
Thumbs up Re: 2 Pc. Valve Covers
Trick Has A New Design Coming Out This Winter Wait And See I Think Jan Or Feb I Can't Wait. :d :d :d
AIR TIME is offline
Old 11-07-2006 | 06:20 PM
Vinny P's Avatar
I hate the winter!!
My 2 year old 2 piece KE covers leak like hell. I had to run a bead of silicone around the 'O'-ring to stop the leak. So much for easy removal.
Vinny P is offline
Old 11-08-2006 | 08:36 AM
KAMMA - I heard/read the leak problem is solved too, but I have no 1st hand knowledge of that. Seems that if they will withstand the dyno, they should be ok in the boat. Guess time will tell. If you think of it let me know how they do ?
Thanks for the input gents !!
Kidnova is offline
grand-illusion
Wanted
7
06-03-2008 10:57 AM
BLOWN85
2
03-02-2008 08:46 AM
nordic95
8
06-02-2006 10:46 PM
Andy
7
06-17-2005 06:19 PM
thegreygoose
4
12-20-2004 11:46 AM
