-   -   Kaama oil pan help (https://www.offshoreonly.com/forums/general-q/144648-kaama-oil-pan-help.html)
bck 11-08-2006 12:59 PM
Kaama oil pan help
I need to know if anyone knows the available clearance to the bottom of boat or can tell me exactly what pans work. Archer marine says to use a 10qt. Dooley pan. Prob is, Dooley has 2 different 10qt. offshore pans. Also a 14 Qt. pan is only 50 bucks more if it will fit. The application is a Gen VI 540 with a 4.25 stroke in a 357 Formula w/ KAAMA surface drive. I've gotten conflicting information in the past about the clearance available with this drive package as far as weather the engine is mounted lower or higher than a traditional drive. Also will a stock type pan work with that stroke or does it have to be a stroker pan ? Thanks.
