-   -   Fogging the 496 (https://www.offshoreonly.com/forums/general-q/144811-fogging-496-a.html)
Sydwayz 11-13-2006 06:45 PM
Re: Fogging the 496
I run about 4 gallons of antifreeze through the motor. Then shut it down. Then remove the fuel/water separator, and mix in the oil and reinstall. I'll then run two more gallons of antifreeze through the motor. Works perfect.
Here is a great thread from last year. Its includes pics of a few homemade winterizing setups, as well as how I modified mine.
http://www.offshoreonly.com/forums/s...+winterize+jug
Sydwayz 11-13-2006 06:53 PM
Re: Fogging the 496
Originally Posted by yesrej
does anyone else pull the plugs and spray fogging oil in the cylinders
I used to do that with my single engine boat. Its too much of a pain with the twins.
Hence the reason that I add in the Lucas Oil Treatment.
I make my Dad add the same thing to his Corvette for winter storage.
Pismo10 11-14-2006 05:46 AM
Re: Fogging the 496
The final answer is...........10:1 gas oil with stabilizer.
http://www.boatfix.com/merc/Bullet/01/01_15.pdf
yesrej 11-14-2006 09:17 AM
Re: Fogging the 496
i want twins so bad but simple things like this is what is making me keep a single.
Sydwayz 11-14-2006 03:00 PM
Re: Fogging the 496
Last season it was 2 hours to replace 15 plugs.
2 hours to replace the 16th plug. No joke. What a mother.
Indy 11-14-2006 03:47 PM
Re: Fogging the 496
I'm doing that next year...how did you do it??
yesrej 11-14-2006 04:21 PM
Re: Fogging the 496
it took me an hour to change my plugs. i make up my own words when i drop a plug in the bilge. this year i didnt drop a single plug. i did drop the wrench though.
Sydwayz 11-14-2006 10:36 PM
Re: Fogging the 496
I literally had to spray WD40 on my arm to get it down between exhausts.
My best advice is to give in, pull up the engine room floor panels (if you have any), and just get under the motor. I can fit under mine, although I have not yet done it.
Indy 11-15-2006 05:08 PM
Re: Fogging the 496
Sounds like a good excuse to change the exhaust. Guess I'll be doing that and change the plugs and wires at the same time. Now, to get those manifold bolts out......
:rolleyes:
double_trouble 10-05-2011 10:15 PM
Originally Posted by Indy (Post 1931808)
You'll burn that gas out of your fuel filter in a heartbeat, I use an outboard gas can, connect it to the intake of the fuel filter and let it burn for a while. The merc trained master mechanics at my marina use a 5:1 ratio of Merc two stroke oil in the gas can. Antifreeze (pink stuff) like everybody else says. You won't burn your impeller next spring if your start it up on the hose.
Anyone know what the Inside Diameter of the fuel lines are for the 496? I am getting my outboard can of engine cocktail ready and haven't done this before.
