-   -   1994 Baja Bandit Question (https://www.offshoreonly.com/forums/general-q/144948-1994-baja-bandit-question.html)
Leathl_WS6 11-12-2006 06:28 PM
A friend of mine is looking at a bandit. He has not seen it yet but it looks like it has a very low gunwale. Does anyone know if stand up bolsters could be put in here or is the gunwale too low?
Ran-Dom 32 11-13-2006 08:55 AM
Re: 1994 Baja Bandit Question
no way, It would look like a hard on in the shower
Leathl_WS6 11-13-2006 09:24 AM
Thats funny. Thats what I thought from the pictures. Thanks
AIR TIME 11-14-2006 10:14 AM
it has a 21degree hull to, so not a good ride in the rough, 240 sport/ ol24 would be better and its 24 feet not 22 and 24degree hull
Leathl_WS6 11-14-2006 10:37 AM
Thanks for the reply.
That is what he is looking for now an Outlaw.
Tazz 11-16-2006 03:28 PM
The 240 Sport/Outlaw is a better ride, but the Bandit is a Fast, Fun boat, especially the 91 model, it has a 15 degree bottom. The boat is a good 10 mph faster with the same power.
ECeptor 11-16-2006 03:52 PM
15°??? I thought the 226ES/240 Sport's had a deeper V than that.
AIR TIME 11-25-2006 09:01 PM
the 240 sports are the same as ol24 24degree hull bolt on swim platform 87 to 97, the 226es are 22 ft or 22.6 boats with built in s p to make them 24ft.
Tazz 11-25-2006 09:35 PM
The 226 has a 20degree bottom, The 240 Sport/ 24Outlaw has a 24 degree bottom. The Bandit bottom was 15degrees in 1991 and went to 20degrees for 1992 and later. The 91 Bandit (15 degree) is a very fast boat, it is the one I would want even though you sacrifice some ride quality.
ECeptor 11-26-2006 03:04 PM
What the the 226ES get re-names as in the early 90's? 240 something, right?
Griff 11-26-2006 05:01 PM
Yep, there was a Baja 240 for a few years in the mid/late 90's with a built in platform. Sit down boat, low profile and small cockpit with around a 20* deadrise. Not sure if it was a renamed 226es.
ECeptor 11-26-2006 07:39 PM
+75mph w/ a carbed 454 mag is a fast hull!
1991 Baja Bandit
Tazz 11-26-2006 08:14 PM
In the mid 90's they renamed the 226 the 240 (length including platform) it makes it confusing, the true 240(square back) is the 24degree bottom.
My brother has a 91 Bandit w/502 Mag carb, it runs 80 on the speedo.
mcourson 11-26-2006 09:17 PM
"+75mph w/ a carbed 454 mag is a fast hull!"
I had the almost the exact same boat(color and power) and it was not a 75mph boat. Fastest I had it was up around 67mph(speedo) and on water with very little chop.
Did run full out next to a guy with a gps speedo. He clocked at 66mph and I still had some more trim for speed, but not 9mph worth.
Matt
