oil capacity
Could someone please give me the oil capacity of a 2000 502 mag MPI and different filter numbers. Thanks in advance!!
Re: oil capacity
Capacity is 8 quarts with filter. The most I've ever put in is about 7 quarts. You just can't get all the old oil out.
Check this thread for filter numbers. http://www.offshoreonly.com/forums/s...filter+numbers |
Re: oil capacity
You can drain all of the oil by installing a drain tube on the bottom of the pan. Mercury makes a kit for this. |
Re: oil capacity
Originally Posted by Sydwayz
Correct, you cannot get all of the old oil out via sucking it out the dipstick.
Re: oil capacity
It can be done. You just need to find a "short person" who teaches Yoga. :D
Re: oil capacity
It already had a hose installed that is ziptied up by drive oil resevoir I just ran it out through the plug hole in the back and drained it into a pan. I couldn't imagine having another engine stuffed in there there's no room now!!
