Need Some Help With My Shifter Parts...
1 Attachment(s)
I had my shifter controls powdercoated and need to have them put back together so they will work correctly. They are Mercury Zero Efforts or Kiekaffers or whatever.
I'm really good at taking things apart, but have a problem putting them back together. I'm sure i'm capable of putting them back together but like I said I want them to work correctly. I have all of the springs, little roller balls, rubber slides, and bushings, just add grease. The shifter was newer so the parts are not worn. The area under the shifter where the sliding mechanical mechanisms are, need to have the powdercoating ground or trimmed away so the parts will fit and they will work properly. Any ideas on a shop or someone reputable that would take on this little job and not just take my parts. |
Re: Need Some Help With My Shifter Parts...
PM me and I will help you.
Eric |
Eric |
He's got
http://www.aquariumaker.com listed as his home page, there is contact info on that site. Hope that helps, and you get your $$ |
(Post 2266905)
Sent a email to that email also. no reply!
| All times are GMT -5. The time now is 03:56 AM. |
