-   -   plumbing fuel system (https://www.offshoreonly.com/forums/general-q/145642-plumbing-fuel-system.html)
carney 11-21-2006 07:42 PM
Which is the proper place to feed the fuel to the pump first or the filter first. Why I ask , my fuel feed goes to the filter first then to the pump and from the pump to the carb. but I see some of the motors here on oso are to the pump first.
excalibur81 11-21-2006 07:49 PM
Re: plumbing fuel system
i have one filter before the pump and another filter after the pump
Ted G 11-21-2006 07:52 PM
Better after the pump to catch any little pieces that come off the pump diaphragm and keep them from the carb. Same holds true if it's injected-small metal particles from pump wear will booger up the injectors.
biginches 11-22-2006 07:53 AM
when i first put the motor together i had the ff/water sep after the pump. i installed a inline filter after the pump
filter
and moved the ff/h2o sep. to before the pump because i wasn't confortable with the can being pressurized with 15 psi(leak would be BAD). :D
eliminatethis 11-22-2006 10:33 AM
i run #10 to ramco filter then # 10 to fuel pump # 8 from pump to another filter # 8 to carb's there is no such thing as overkill
Jb-fse 11-22-2006 03:18 PM
Run A Filter In Front Of The Pump A Fuel Water Seperator Is Best. After The Pump Run A Fine Micro Filter (10) To The Engine Feed.this Keeps Water Out Of The Fuel Pump And Fines Out Of The Engine.
