-   -   Timing 454 Mag MPI (https://www.offshoreonly.com/forums/general-q/147810-timing-454-mag-mpi.html)
Donzi502 12-25-2006 02:34 AM
Timing 454 Mag MPI
Guys how do you time a mpi mag without useing a merc electronic tool to turn off the knock sensor. Can i just unplug the dam thing and time it normal. Thanks. Jason
Smarty 12-25-2006 09:29 AM
Re: Timing 454 Mag MPI
Mercury sells a timing plug which plugs in the test harness. It sells for about $10.00. It jumps A & B together so you can set the timing with a timing light. (This turns off the computer from adjusting the timing). Or call Alan Jones (my father) he has two 502 MPI's and has been there and done that. His number is 856-589-1070, he said to call him if you need help/advice on the timing.
TylerCrockett 12-25-2006 10:04 AM
You can also take a paper clip and jump across the A & B terminal on the diagnostic plug it will be the black and white wires side by side. After you jump the 2 wires bring the Rpm's up to about 1200 RPM to help steady the timing.
Elite Marine 12-25-2006 12:36 PM
Do like Tyler says. I'll only charge you $ 9.00 for the paperclip bent to a perfect fit :drink:
