-   -   Mass Flo efi system (https://www.offshoreonly.com/forums/general-q/148118-mass-flo-efi-system.html)
Bob280Silencer 12-29-2006 10:07 PM
Mass Flo efi system
Does anyone know anything about this efi system? www.massfloefi.com Sounds cool but I want to check around before I drop 3K.Thanks,BOB
Elite Marine 12-29-2006 11:01 PM
Re: Mass Flo efi system
Look into Autronic. Seems to be a very nice set up also.
http://www.autronic.com/
cobra marty 12-30-2006 05:57 AM
They use a mass air flow sensor and not speed density system. ?is it marine durable? The sensor is how it can self tune.
Bob280Silencer 12-30-2006 12:21 PM
Marty, www.massfloefi.com They use a air flow meter from a LS-6 chevy inside the air filter on top of a 1000cfm throttle body. BOB
articfriends 12-30-2006 02:51 PM
I read all thru their site last night,it seems they are using a 302 ford ecu,I couldn't figure what they are doing for a timing curve/timing map though. It seems like a good idea,a person could almost duplicate what they have done for less than 1/2 if you were ambitious,Smitty
Bob280Silencer 12-30-2006 03:48 PM
Smitty,The only info they need is approx hp.(for injector sizing)When the system is installed,you need only set the timing and fuel pressure.(49 lbs)They will probably do a custom curve depending on the application? BOB
Bob280Silencer 12-30-2006 04:01 PM
Smitty,That's 40 lbs fuel pressure. BOB
Bob280Silencer 12-31-2006 11:53 AM
ttt ?
