-   -   454 mains bolt torque (https://www.offshoreonly.com/forums/general-q/148261-454-mains-bolt-torque.html)
f_inscreenname 01-01-2007 01:17 PM
Hi folks and thanks for looking.
I am about to reinstall my crank and went to look up the torque specs for the caps and my books are all over the place. From 95 to 80 lbs.
It is a 1986 MIE340 (mercruiser) 454ci
2 bolt mains.
Any help?
mrhorsepower1 01-01-2007 01:28 PM
Re: 454 mains bolt torque
100 ft lbs. with 30 wt motor oil
f_inscreenname 01-01-2007 01:58 PM
Now that is strange. My merc book says for the model 330 and 340 is 80 lbs
My Volvo book with Chevy section says 110lbs
A website I was just on says 110lbs for the 4 bolt mains?
mrhorsepower1 01-01-2007 03:49 PM
One a two bolt main block 100 ft. lbs. is what I torque to. 110 ft. lbs. on a 4 bolt. DO NOT use moly lube! It will change the torque dramtically.
birdog 01-01-2007 04:14 PM
I would follow what Dean said.
f_inscreenname 01-01-2007 06:17 PM
Finally got a hold of a former Merc tech friend. He said, OEM Merc book, Service manual #9 says 110lbs with oil only. He also checked the service bulletin index for any changed specs for the engine and didn't find any.
Thanks folks for the help.
