-   -   Who Makes The Better Cam (https://www.offshoreonly.com/forums/general-q/148290-who-makes-better-cam.html)
myscarab30 01-01-2007 08:38 PM
Im sure this has been talked about before on here but what is everyones opinion Comp? Crane? Lunati? I will be using one of these in my stock 454's with rect. heads and gil exhaust with dry pipes
Donzi502 01-02-2007 12:59 AM
Re: Who Makes The Better Cam
Howard do a nice RV cam that works great in a boat. You can find them on eBay under LBW engines. I got two and they are great. I cut some base circle off one and pushed it to 600 lift. Stock they are 226@ 50 and 544 lift i think. I will post the address is i can find it. Ther are 125 US dollars. Cheep. My cam guy checked them out. They are hard and true and well finished. Jas
myscarab30 01-02-2007 07:10 PM
Ill check them out...Anyone else have any opinion
Donzi502 01-02-2007 07:19 PM
I dont think that guy is on eBay now. You may have to go direct to howards cams. J
AIR TIME 01-02-2007 08:27 PM
I like my Isky cam and springs hyd roller:D
JCPERF 01-02-2007 08:56 PM
For your application, they all make nice cams and some of the same companies use the same cam cores[base material from the same source].I use Crane for the lower HP engines and use Bullet cams for the high HP engines if that is any help.
myscarab30 01-03-2007 06:37 AM
what cam would be a good choice.. i want a slight lope and wont run over 5000 rpms
Thanks guys
Scarab3DMC 01-03-2007 07:09 AM
yo Bro did you install them Shifters ??? lets see pics...:evilb:
myscarab30 01-03-2007 05:36 PM
Yes i did ...Thanks again ...Ill have to see if i can find a pic of them
Fenderjack 01-03-2007 05:55 PM
All of them grinde and make nice cams, comp cams arree out the ass and every where, depending on the drind ya want, they all are good, anybody know where general kinetic's went to????
