-   -   Which exhaust flange gasket? (https://www.offshoreonly.com/forums/general-q/148459-exhaust-flange-gasket.html)
rv 01-04-2007 07:05 AM
I would like to know if anyone has had luck using a copper gasket for the header flange to head gasket. I know the standard CMI one's work to some level but seem to crush after time and start to leak. Does copper gaskets work any better?
Thanks,
Rick
Elite Marine 01-04-2007 07:54 AM
Re: Which exhaust flange gasket?
Rick -
Usually you need to retorque the bolts to prevent this issue.
How are the engines coming?
Kirk
rv 01-04-2007 09:34 AM
Kirk,
I did do the retorque. However, when we removed them this fall they were sealed but close to failing. I was wondering how much longer before they would fail and if copper gaskets would work better.
Engines are in final stages, I plan on painting them Saturday.
Rick
Elite Marine 01-04-2007 09:54 AM
Any major issues? Or just standard rebuild/freshen?
klaw 01-04-2007 12:02 PM
Rick
Are you using locking fasteners
Klaw
rv 01-04-2007 12:10 PM
No major issues, everything looked good except for the soot buildup and glazed cylinders from running so rich. Turned out to be basic refresh job - rings, bearings, springs, rebuild lifters, new rockers.
Klaw, no locks. I have heard of those that lock. After inspecting the gasket it doesn't appear to be an issue with the bolts loosing but the gasket crushing over time and gap opening up. I installed new gaskets last winter, retightened once about July. The bolts didn't seem loose this fall when I took them off but the soot markes on the gasket looked like it was close to the point of leaking.
Rick
mrhorsepower1 01-04-2007 12:11 PM
Rick,
What works the best is ARP header stud kit with the SCE copper gaskets. Once the engine is run then I retighten the studs and they do not loosen again.
Dean
rv 01-05-2007 12:30 PM
Dean,
Thanks for the input. That copper works ok with the aluminum head and stainless steel header flange?
Rick
Strip Poker 388 01-05-2007 01:01 PM
I use the fepro 1411 .rettourqe after the dyno run and again once after I run it once in the boat .Stays tight all summer.
Havent tried the copper ones yet.
eliminatethis 01-05-2007 02:05 PM
on turbo or blown eng. i have used earls pressure seal gaskets never a failure also arp studs
