Switchin corsa quick and quiet to captains call
Im thinking of switching from corsa quick and quiet 2 to the captains call. I want to be able to switch it. I was wondering if I need to order the whole kit or just the diverters. Also do you think it will be a tough job?
Thanks guys |
Re: Switchin corsa quick and quiet to captains call
I can get you the kits. We are a Corsa distributor. It's not a tough job to swap it over from what you have. The diverters will need to be replaced to the electric ones with the wire harness and a switch.. :) Call me if you need them.. :) Jamie / Lakeside 570-639-2628
Im going to need a set of exhaust tips too. Louder the better!
Originally Posted by pol98xc6
(Post 1984253)
if you don't mind but what is the difference between the two systems?
One exhaust is thru hul thru prop all of the time (Q&Q 2)... The other one allows you to switch between thru hull thru prop.. :) Jamie / Lakeside
Thanks I will definetly give you a call around the end of the month!
(Post 1984327)
whats the diference between the captains call and the quick and quiet plus?
Captains call is a non muffled switchable system.
Quick & quiet 2 is a non switchable thru hull & prop system with mufffled tips. Quick & quiet +is a switchable thru hull & prop system with mufffled tips. :) Jamie / Lakeside |
| All times are GMT -5. The time now is 09:10 PM. |
