Alpha Drives???
A friend is in need of help regarding Alpha drives. What is the difference betweeen Gen 1 and Gen 2?
I assume they are both the same bolt pattern, gimbal, etc... Thanks, Kirk |
Re: Alpha Drives???
anyone?
Re: Alpha Drives???
Re: Alpha Drives???
Alpha 1 and Gen II are not interchangeable. Gimbal ring bolt patterns are different. I believe the transom assy mounting bolt patterns are the same though. If going from Gen I to Gen II the entire system has to be swapped.
| All times are GMT -5. The time now is 11:34 PM. |
