EMI thunders
What can I expect if I drop the bucks and go aftermarket exhaust vs. stock manifolds. Just wondering some of your experiences. I have a 502 MPI with a cam and custom tune from Arizona speed and marine. Thanks
Re: EMI thunders
1500.00+
I SAW A SET OF GILL MANIFOLDS ON EBAY FOR 1300.00 I THINK NEW. http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget |
Re: EMI thunders
Well it seems that every onse says that it is one of the cheapest and largest hp gain for bolt on products............
I cant remember the "Rule of thumb" amount of HP mostly gained though Jr. |
Re: EMI thunders
Best money you can spend on your boat. My personal choice would be buy the lightest you can aford. I think the weight saving is as good as the HP gain. You can reprop for more lift as well and get a double wammy if you get it right. Jas
Re: EMI thunders
I just bought a new prop last fall took it out once but had eight people on board so I really couldn't see what it could do I was hoping to pick up a couple hundred rpm 24 5250 26 around 4800. I was wanting to land in between there so I bought a labbed 26 hopefully that will do the trick. Most of all I was hoping to shed some weight and pick up a little extra power out of some manifolds or headers. Since the engine already has a custom tune and cam from the previous owner, I figured it might benefit from different exhaust.
Re: EMI thunders
I'm considering going from stock iron to EMIs also. Anybody got any real numbers or rpm/speed gains? Yea, I know the bigger hp engines should gain more than stock. Anything negative about the EMIs?
Re: EMI thunders
I have the EMI Thunders with long stainless risers. I saw 1 to 2 MPH increase. Sounds better runs better. Sleep better with no wet riser joint. This place has a good price. I bought my oil cooler from them last year. They give a discount for OSO members. They have good service and follow up. http://www.tpmarine.com/index.asp?Pa...S&Category=110
If you have any more questions let me know. Good Luck!! |
Re: EMI thunders
call fred at trick marine,he has very good pricing and takes care of his customers.
Re: EMI thunders
Originally Posted by awsomethunder
(Post 2002842)
We've sold a lot of EMI Thunders and have had good results. The five year warranty is also a plus. If I can provide anyone with competitive pricing, please give me a call. Fred Trick Marine 866 921 4553 ww.trickmarine.net |
Re: EMI thunders
Originally Posted by kemiller
(Post 2000907)
| All times are GMT -5. The time now is 03:59 PM. |
