-   -   Bravo upper & lower questions (https://www.offshoreonly.com/forums/general-q/150222-bravo-upper-lower-questions.html)
S4Hadi 01-28-2007 05:31 PM
From what I can see in the Outrdrive classifieds, the mercruiser bravo upper works with both a bravo 1 1.5 Ratio and/or a bravo 3 2.0 Ratio lower?
So one can exchange from going from a bravo 1 to a bravo 3 (and vice versa) by simply exchanging lowers & props?
How much labor and parts is there involved to exchange lowers?
Thanks,
Jamal
Vinny P 01-28-2007 06:30 PM
Re: Bravo upper & lower questions
It may take about 1 hour to swap lowers. That includes draining and refilling the gear lube.
t500hps 01-28-2007 07:48 PM
1 hour for a novice. It's only held on by 7 bolts...but you have the remove the rear zinc first too!
Vinny P 01-28-2007 10:11 PM
You are right, it takes longer to drain and refill the gear lube, than to unbolt the lower. Especially when its cold.
S4Hadi 01-29-2007 06:51 AM
If it is that easy and with the bravo 1 and bravo 3 lowers being interchangeable...I am supprized that no one has done a direct comparisson between the two drives on the same boat.
From what I understand the Prop Shops (BBLADES/THROTTLE UP etc.) have a prop testing loaner program.
Does anyone have a bravo 1 lower (or complete bravo 1) they would like to exchange with a bravo 3 for a couple of weeks this summer?
Maybe we can put to bed the real differences in performance on a single engine V-bottom boat.
Please advise.
Jamal
