-   -   Question about new bearings (https://www.offshoreonly.com/forums/general-q/150499-question-about-new-bearings.html)
Rookie 02-01-2007 12:12 PM
Question:
If you have a good engine that has no ticks, knocks, holds 40lbs oil pressure at idle when first started, 15 lbs after a hard run. Is it ok to replace the old bearings with new bearings and not have the crank polished or ground, when you have it pulled to replace gaskets due to oil leaks??
just curious
the duke 02-01-2007 12:35 PM
Re: Question about new bearings
If the crank measures within spec, and has no damage to it, you don't have to touch it. Measure, get your clearance right, and put it together.
Pat McPherson 02-01-2007 12:57 PM
My 502 did exactly what you are describing at about 500hours. I freshened it with new rings, bearings, oil pump, and did a valve job.
She has been running great with another 140hours so far.
Make sure that you also replace the cam bearings.
