-   -   Comp cams blower cam (https://www.offshoreonly.com/forums/general-q/150570-comp-cams-blower-cam.html)
badluck 02-02-2007 02:24 AM
I'm in the process of rebuilding my 525SC and I'm considering staying with hyd flat tappet cam.
Would comp cams CB 280AH-14 be a better choise than the stock Crane?
Below are the specs:
Duration .050 232 in/237ex
LS 114
Gross lift .547 in/ex
Valve timing .006 30/70 in 82/26 ex .050 timing not listed.
bl
Griff 02-03-2007 03:42 AM
Re: Comp cams blower cam
I doubt you would see any improvement with it. The specs you posted are pretty close to the stock cam. I gained about 100rpms going to a Crane 731 roller in my 525sc. It also has better midrange.
badluck 02-03-2007 04:32 AM
Thanks. Maybe I should bite the bullet and go roller.
38tg 02-04-2007 04:08 PM
do the roller...... put same cams in mine wiped out on breakin. had to break in with single valve springs..
iamfaster 02-04-2007 04:52 PM
what else do you plan on doing? Heads, compression?
badluck 02-04-2007 06:40 PM
I will bump up the compression a bit with .060 SRP flat top pistons, cleaning up the stock heads and probably do a hyd roller cam.
bl
