502 to 540... need 1 pc. crank
I've been looking around for a 4.250 1 pc. crank to go from 502 to 540. My block is GM (ZZ502) so I gotta go with the 1 pc. crank. I'm finding that the 1 pc. cranks can be hard to come by.
I'd like to go with Callies, Crower, Lunati, something USA made. And hopefully in the $1,000 to $1,200 range. Any dealers or suppliers here at OSO that have them, or can suggest who to contact about a 1 pc. 4.250 ?? Thanks !! btw, I posted on this subject yesterday but something wierd happened to my computer, and my post got gone, along with some other stuff....wierd |
Re: 502 to 540... need 1 pc. crank
you can use the two pc. rear main seal old still gen. 4 crank there is a drop in adapter made to fit that block so you can run the two pc. seal i have used them many times with good results no leaks at all on high output motors i thank scoggens ****ey chevys them
Originally Posted by mikes280
(Post 2013642)
Thanks mikes280 |
I Run The Adapter In Mine I Have'nt Had Any Leaking From Mine Yet It Has 3 Years On It
I would definatly use the adaptor. One piece has a large diameter seal and so you get a much higher speed where the crank meets the seal. Useing the adaptor the seal is much smaller and a lower friction speed. Means more reliable seal. And cheeper cranks. I have been led to beleive they are very reliable and dont leak if installed well, Jas
We are a Callies dealer if you have problems getting one give me a call.
Thanks Mike Roccard MArine Engines www.roccardmarineengines.com [email protected] 570-956-2840 |
Thanks for the replies everyone. I'll get in touch with my engine guy and discuss using the adapter. Sure would make finding a crank allot easier.
Thanks again !! |
Wow, I thought 1pc cranks would be easy to find given how long the blocks have been around.
I used the adapter for a "old style" two piece seal in my 502 block. I never had any issues with leakage...
| All times are GMT -5. The time now is 05:36 PM. |
