Installing exh.manifold&Risers backwards
Hello,im in the process of mounting a 496 in my deep V fishing boat in disguise.What do you think of this,i have:
Crusader FWC setup VolVo SP(same as duoprop with one prop) 3'' thru hull exh(should i go to 4''??) I think i want to use the crusader manifolds ,they have a nice smooth transition to the riser and it dumps the water in farther downstream in the exhaust.Could i mount these on backwards so i can get some space to mount mufflers under the engine or on the sides of the engine also,would it be ok if the exhaust has a slight uphill climb to the stern.Like most others building a 496 im wondering about camshaft selection-flat tappet hydraulic,i am installing a camshaft oiler/shower in the valley to eleminate the problem the BB has of killing new cams.-thanks,Don 71' Chris Craft Lancer 23 |
i believe the bolt patern is the same left or right. so it shoold work. as for the incline in the exhaust , i would say no. you ll increase your chance of reversion.
Yes you can mount them backwards. Just check out any V drive boat.
As for the incline, that will depend on the riser setup you use. Gary |
thanks for the info guys looks like it will work-Don
| All times are GMT -5. The time now is 04:47 PM. |
