Parts needed for 25 Outlaw! Any ideas?
hey guys-
I'm needing a new trim tab guage. Any ideas where to get one? The lights on my guage are burned out on my port side. Do I need a whole new guage? I'm a rookie with all of this! Also, I'm needing a new stock cover for it. I want all black. The one I have now leaks like crazy! And, my speedo guage is liquid filled and the liquid has turned kinda brownish. Any idea why/ And where do I go to have this fixed? It doesn't effect anything but it sure looks like crap! It's a Gaffrig(sp?) Guage. My boat is a 2002 Baja 25 Outlaw. I hope someone can point me in the right direction! |
What kind of trim tab guage???? What tabs?????
Get a custom cover made by someone in your area out of Sunbrella. If it just water seeping through, you can rewaterproof it. A black cover will fade and the cockpit will be very hot when take it off. Speedo is filled with Glycerin. There should be a plug you can remove. drain and replace fluid. Glycerin can be bought at most drug stores. |
Yes you can replace the bulbs. reach under the dash and you should see the mount in the back of the guage.
A 2002 25OL - the gauge is probably an Instatrim one. If all the lights on one side went out at once, it could be a poor connection. If one or two went awol, then you need to replace the gauge. $170, I think.
Freeryd
I have new origanal Baja 25 Outlaw covers in navy blue, purple and grey if you are interested. Brian |
| All times are GMT -5. The time now is 04:46 AM. |
