454 420
I have a 454 .030 built to 420 specs but I am running a 750 eldebrock marine carb will I gain anything at all on top end if i switch to a 850 sea demon?
The 420s came with an 800 holley. So you might gain a bit.
But then again, the the 410hp 502s came with a 750 weber/carter/edelbrock, so maybe not. Does that answer your question?:D Gary |
I have a pair of 330 hp engines that were redone and dynoed at 469 hp using out of the box eldebrock 750 marine carbs. Dyno sheet showed I did not need more carb.
Thanks I figure I would just leave it alone
A wise decision!
Originally Posted by k24u
(Post 2046865)
| All times are GMT -5. The time now is 04:52 AM. |
