-   -   efi question (https://www.offshoreonly.com/forums/general-q/153393-efi-question.html)
Bob280Silencer 03-11-2007 11:02 PM
efi question
A buddy has a '02 502 mpi engine that just went "full rich" Runs so fat,fouls plugs instantly.Will the efi temp sensor cause this? Thanks BOB
TylerCrockett 03-12-2007 06:56 AM
Yes I would replace the water temp sensor.
Bob280Silencer 03-12-2007 10:05 AM
Thanks,Tyler. BOB
Dave_N 03-12-2007 10:43 AM
The ECT sensor may be the cause, but you want to check for trouble codes before you start replacing things. You can check with just a paperclip and 12 volt LED. Also, just FYI, the last production year for the 502MPI was 2000.
Dave
Elite Marine 03-12-2007 05:36 PM
Sounds like its in enrichment mode. Usually the temp sender.
800XCR 03-12-2007 06:59 PM
Make sure the map sensor is plugged in or not damaged. This will show up at idle.
Bob280Silencer 03-12-2007 11:14 PM
Thanks guys,checked the map.I have a spare efi sensor,easy enough to change.I go from there.
Dave,don't know? It's a powerQuest('01 not a '02 like I thought)definately is a 502 mpi ??? BOB
Pismo10 03-13-2007 06:41 AM
Dave
Merc made both the 502 Mag and 496 in 2001, they rolled one out while they closed down the 502.
Bob280Silencer 03-14-2007 09:52 PM
Well,renewing the temp sensor didn't fix it? Got no codes and the fuel is fresh.Unpluged the map and the sensor and the scan tool picked up on that so it is working.Thanks for your help.I'll fill y'all in when I figure it out. BOB
TylerCrockett 03-15-2007 06:28 AM
Did you check the fuel pressure?? You may have a regulator problem.
800XCR 03-15-2007 07:48 AM
Or leaking O-Rings or stuck injecter.
Pismo10 03-15-2007 08:04 AM
Now the 496 is going the way of the dinosaur..
Bob280Silencer 03-15-2007 09:12 AM
Tyler,That's on tonights list!
800XCR,all 8 plugs are fat,the boat was run every month during the winter,don't think I've got 8 stuck injectors.Thanks,BOB
bjablonski 03-15-2007 08:44 PM
I had the same problem with my 98 502's. Checked fuel pressure with a gauge and it was extremely high. Changed out the regulator and everything was fine after that
Bob280Silencer 03-15-2007 10:55 PM
bjablonski,fuel pressure was suppose to be checked tonight BUT this brunette called from Baton Rouge.My buddy is going to have to wait 'till tomorrow!! lol BOB
Mr Gadgets 03-16-2007 04:46 AM
Any pics of the brunette?? :)
offthefront 03-16-2007 07:53 AM
:rolleyes:
:drink:
Bob280Silencer 03-16-2007 08:30 AM
Mr Gadgets,That's funny! No pics yet but it looks like it's going to be a good summer. BOB
TylerCrockett 03-16-2007 09:44 PM
Does she have a fuel pressure Gauge :D
Bob280Silencer 03-16-2007 09:57 PM
Fuel pressure guage? Why would she need a ....Oh,right,my buddies boat.Completely forgot about it! lol She got my pressure "up"!! BOB
Mr Gadgets 03-18-2007 11:24 AM
Now if you can just get your buddy's boat running.. LOL
Any luck with that??
You are allowed to follow up with pics of the Brunette!! :)
Bob280Silencer 03-18-2007 06:51 PM
We're lookin at the fuel pressure tomorrow night.Pretty sure it's the regulator.The system is pretty simple.It's running at 6.8 gals per hour now,pretty fat!! You helped me set the backlash on my bravo XR last year,thanks again.The brunette... that will take some time.Second date is this weekend at the boat races in Miss.High hopes. BOB
Bob280Silencer 03-20-2007 10:27 PM
OK,here's the deal.Water in the pressure regulator?! How's that possible you ask? When my friend washed his engine(some time ago) the vac hose was off the reg(at the manifold) and got water in it! Finally rusted and stopped working.And that's the rest of the story! BOB Tyler,where's those pics of that manifold? lol I'm going to "assume" I'll have to fatten this thing up with the improved air flow?
