-   -   What to use to waterproof mooring cover? (https://www.offshoreonly.com/forums/general-q/154139-what-use-waterproof-mooring-cover.html)
djtalon 03-21-2007 02:39 PM
Some people say thompsons waterseal and the others say the stuff from west marine. What are you guys using??
thanks
David Stotz 03-21-2007 06:16 PM
I've always used the Starbrite product. Wash the cover every spring, let it dry and water proof it. Never had a problem with it leaking even in pouring rain. Cover is about ten years old. I was also wondering about the Thompsons. The Starbrite is over $20.00 a gallon. Is the Thompsons less expensive ?
Dave
Ted G 03-21-2007 08:11 PM
Sunbrella recommends 303 protectant after a good cleaning with mild soap.
benztech 03-22-2007 11:55 AM
Our shop has always used Thompsons on the soft tops for our cars. ( Benz dealer )
KNOT-RIGHT 03-22-2007 12:36 PM
My interior guy told me about the thompsons water seal
I laughed. But I tried it . Goes on milky white.
When it dries you cannot even tell you did it.
It worked awsome! I could not beleave the results.
sleeper_dave 03-22-2007 02:47 PM
Do you just spray the thompsons on?
I've heard of using it before, and it sounds promising. Hopefully a bit cheaper and more effective than the stuff at west marine.
KNOT-RIGHT 03-22-2007 02:56 PM
paint brush.
You wont beleave the results
waterbum 03-22-2007 04:58 PM
I put a gallon of Thompsons in a deck sprayer (the kind you pump up )and let it rip. Works great. I have a canvas cover and the water beads up and runs off like it's covered with a plastic film. I used to buy 5 or 6 spray cans of the silicone spray. Most of that blew off into the wind while I was spraying. Thompsons is the only way to go in my opinion. I tried the brush method, but it seemed to put on a really heavy (wet coat) and took a long long time. Spraying takes about 10 minutes including setup and cleanup. Leaves more time for standing back, admiring your work and having a beer.
Ryan00TJ 03-22-2007 05:44 PM
I used the Thompson's on a cover back in the late 90's and it worked great at repelling water but after about a year the cover became very stiff and unflexible compared to before using the Thompsons.
