-   -   TPS...adjust or replace?? (https://www.offshoreonly.com/forums/general-q/154312-tps-adjust-replace.html)
rangerrick63 03-23-2007 06:11 PM
99 454 mag mpi, idles great, runs great when cold. After it gets warm, & above 1000, surges real bad, & loads up to the point of stalling, unless I play with the throttle. Above 2000 seems to run ok. I checked all plugs, wires & cap, all ok. I removed the throttle body, cleaned the butterflys, & replaced the IAC ( it didn't look real good). No change, I'm thinking it may be the TPS, but don't have access to a Scan Tool, is there a way to check with a digital multi-meter, & if so, how? Should I try to adjust or simply replace it? I don't think it's the MAP sensor, due to it idling ok, but any insight on this would be a great help.
mats 03-23-2007 06:39 PM
If it idles OK the TPS is not so likely to be faulty. Does it surge under load or only when not in gear? Does it behave OK at higher rpms under load?
H2Xmark 03-23-2007 06:45 PM
your TPS has 3 wires, should be grey,black and blue, the blue wire if i remember right is the signal wire from TPS to mefi computer, back probe this wire with a digital meter red lead and take the black lead and ground it , you should have .50volts at idle, move the throttle and watch the meter, should sweep up to 5 volts at WOT
rangerrick63 03-23-2007 08:11 PM
It surges under load, & without a load, it does seem to clear up above 2000rpms. The troubling thing is that is loads up so bad that it will stall if I don't play with the throttle. Off idle, if I move it just a click on the throttle, at times there is no change in rpms, & other it revs up & will surge bad, that's what was making me lean towards the TPS. I do appreciate any input, being that good Mercuriser mechanics in the Gulfport area are tough to find right now.
rangerrick63 03-23-2007 08:12 PM
Thanks, I will check that tomorrow.
hillbilly24 03-23-2007 10:25 PM
I would look at the fuel system, if you have access to a fuel pressure guage that is where I would start. I believe that engine is suppost to run 49 PSI at idle with the regulator unhooked, the one down on the side of the engine not the one on the rail, it's just s dummy and is capped from the factory. I'm not positive about the presure spec on thast though mybe someone with the manual can verify that for you. If your engine has a VST pump and filter check the filter screen in there, they get plugged up and take out the pump.
mats 03-24-2007 02:17 AM
43 psi according to my manual (Seloc) with the vacuum hose unhooked. I think you will need a scan tool. It is possible to trouble shoot with a DVOM but it may take quite some time. It could be basically any sensor, a short somewhere, an open somewhere, etc.
rangerrick63 03-24-2007 09:26 AM
That is a direction I had thought of, but didn't go into any pressure checks. I'll have to do that, my fuel pump is easy to get to, so that is a quick check. I'll do that today, thanks.
rangerrick63 03-24-2007 09:28 AM
Will a scan tool for automotive work? I do have access to one of those, but I've been told that it wouldn't work for Mercuriser.
Vinny P 03-24-2007 10:18 AM
No it wont work. You need either the Quicksilver or Rhinda scanner. There is a way to jump the connector and read flash codes, but I dont remember how . I am sure someone here knows or just do a search , it has been discussed here before.
mats 03-24-2007 10:22 AM
I dont think an automotive scan tool will work but maybe someone else knows for sure. What you want to look for with the scan tool is primarily unusual values of various parameters under the various operation conditions eg engine temp, throttle position, manifold air pressure, etc. These may give you a clue of what is going on in the engine. Who knows, you may even get lucky and get a trouble code but dont count on it. The beauty of the scan tool is that it tells you what the ECM thinks is going on in the engine. I may eg think that the engine is cold, flooding the cylinders with gas to the point where it stalls...
Dave_N 03-24-2007 11:33 AM
I agree with hillbilly, checking the fuel pressure is a good place to start. The Coolfuel systems have a screen in the return line that can clog and cause the fuel pressure to get too high. This or a bad ECT are some ot the most common causes of a rich/flooding condition.
It wouldn't be a bad idea to check for trouble codes. The link below will explain how.
http://www.offshoreonly.com/forums/s...d.php?t=103342
Dave
rangerrick63 03-25-2007 11:59 AM
Ok, I think I may be on to something. I won't be able to get a pressure guauge until tomorrow, & I hate not doing something, or just call it curiosity. I took my regulator off, the filter under it is clean, but however, I did find a rust hole in the vacuum end of it. I couldn't seem to get it to move with a vacuum pump, so I stuck a small drill bit & pushed lightly, it did move, but it took a bit of force. Does that sound like it may be stuck, & this is what my troubles have been? I'm sure the rust hole can't be good...LOL. I'll be ordering a new regulator, but I really hope this is what my problem is.
