Originally Posted by 26sonic
(Post 2162397)
what about this mod to the throttle plate ?
Looks like a different throttle plate. Raylar told me to increase hole on my standard to 5/16" and it really helped |
Originally Posted by DPA
(Post 2167661)
If you went 496 standard to HO and it surges at idle, check the TPS for .6 volts into the ECU. Adjust if nessary. If it still surges drill out the idle hole on the throttle plate to 5/16 in. It cured my surging issue when I went standard to the HO cam and ECU. Just remember to stuff a rag behind the throttle plate to catch the shavings and use a shop vac to vacuum them as you pull the rag out.
Does anyone have any HO ECM's they are looking to get rid of? |
| All times are GMT -5. The time now is 11:52 AM. |
