Where can I get Gil manifolds pressure checked
I think I have a manifold that is leaking or possibly cracked. Where, or can I get them checked?
Thanks |
NAPA ? I'd call them and ask.
Do it yourself, If you have it off the engine. Simply hook a water hose to one end and plug the other. You should be able to get 35-50 psi that way. That's more than your engine water pump will make.
Originally Posted by Payton
(Post 2069563)
I've checked alot of manifolds using air, Just plug one end, put air to the other side, with some sort of gauge so you can see if the pressure drops when the air is turned off, real easy...
| All times are GMT -5. The time now is 02:06 PM. |
