-   -   Inconel exhaust valves (https://www.offshoreonly.com/forums/general-q/154651-inconel-exhaust-valves.html)
ls1nova 03-28-2007 11:08 AM
Is there any difference in the appearance of an Inconel valve compared to a Stainless? How do you know if you have them or not?
Thanks,
Frank
RedDog382 03-28-2007 05:33 PM
Inconel is much more durable than stainless and is best for exhaust valves. My understanding is they are composed of iron and nickel ... perhaps they would be magnetic?
Should be some kind of marking or numbers on the valve stem?
OL40SVX 03-28-2007 06:41 PM
Inconel 625(non-hardenable) and 718(hardenable) are not magnetic.
H2Xmark 03-28-2007 06:43 PM
Inconel steel is heavier than stainless,
Noise Pollution 03-28-2007 08:12 PM
Hey Frank, Put a tourch on and see how much heat it takes.:evilb: :D
Don't you like a wise azz?
KAAMASCARAB 03-29-2007 09:06 PM
I was told by someone at Manley that a magnet should stick to the valve stem 1/2 way up if it's inconel.
Noise Pollution 03-30-2007 07:08 AM
He already did that. It stuck. Didn't stick on the valve.
ls1nova 03-30-2007 10:49 AM
Well, the heads are already assembled, but it didn't stick to the valve side, but it did to the stem side. Only problem is, the the stainless intake valve did the same thing. I guess I'm going to have to trust AFR that they are in there.
Frank
KAAMASCARAB 04-01-2007 11:25 AM
What year is your nova? I have a chassied '62.
ls1nova 04-01-2007 11:39 AM
It's a 64. Here are some pix of it. http://www.cardomain.com/ride/527714
What's in your 62? Post up a pic.
Frank
