-   -   How do you check PISTON to VALVE clearance? (https://www.offshoreonly.com/forums/general-q/154885-how-do-you-check-piston-valve-clearance.html)
1BIGJIM 03-31-2007 09:39 AM
I have a hydraulic roller and the plunger in the lifter goes down when lifting the valve even with a test spring on it. :(
What is the proper way to make sure I don't have a valve hitting a piston.:eek:
kevinr 03-31-2007 10:07 AM
First pump up the lifter with oil or bottom the plunger out in the lifter if you don't have a solid roller lifter. Take medeling clay , place a small amount on the piston so the valves will contact. replace cyl head ,set up valvetrain on#1 cylinder with zero lash, turn engine over til on comp. stroke on#1,remove head check the indent in the clay. Now with a dial mic. place the end of the mic opposite from meas. face basically where the rod comes out . wich is like a hieght mic. Lightly set the mic squarely on the indent, insert the rod thru the clay until it contacts the piston . Thats your clearance!! Now add the compressed head gasket thickness ;usually .039".
I shoot for min. .100" ,,,, hope that helps
BY U BOY 03-31-2007 10:07 AM
you need a solid lifter so you have no compression in the lifter while checking the clearance.
1BIGJIM 03-31-2007 10:15 AM
I did pump up the lifter with oil
I never thought about pushing the plunger to the bottom then setting the lash. I did not want to ruin a brand new lifter:eek:
kevinr 03-31-2007 10:43 AM
nothing in there to hurt
1BIGJIM 03-31-2007 11:14 AM
Thanks. It worked just fine:drink:
