steering issues...help
somebody helped themselves to my steering system before i got my boat, so it is missing a couple things, being new to boating, im not really entirely sure what goes where.... it is an 89 fountain with trs drives, there must be somewhere to see like online microfiches or something so i can see what all i need, so far what i see..... pump bracket and lines are there, but no pump, and the pump lines are not connected to anything at either end, i guess i need a steering ram or something, the tie bar is there, on the transom on the outside there is no hoses or anything else steering related, the only hoses i see are all the braided lines for the tabs. please help an idiot here....
nobody at all?
Probably not a hyd steering setup, just the standard PS setup. Otherwise you'd have hyd. lines on the outside of the transom for the rams.
well what did most 89 fountains have? it has some mount looking things that look like a ram could bolt to on the outside....
Originally Posted by turbosonoma
(Post 2080995)
..... on the transom on the outside there is no hoses or anything else steering related, ..........
This is what I was going on. Any pics? |
not yet, ill take some tomorow i suppose.
2 Attachment(s)
here is couple pics.
looks like your rams are gone:D . They should go from the mounts on the transom to the mounts on the drives, below the tie bar. The lines would go from the rams to the fittings in the transom. What do you have on the inside, and behind the steering wheel. If it is full hydraulic system there should be some hydraulic lines going to the helm behind the steering wheel. If there is a cable at the helm to the back of the boat then you have hydraulic assist. Hope this helps.
so then what about the inside of the engine compartment, there is no pump, and whatever attaches to the pump as well, lines and everything are all there, just whatever, is it best to just buy thge peices to make it all work or buy a complete steering kit with everything new?
i have not seen any hydraulic lines going to the helm. |
rams, outside hoses, PS pump/pumps, HP filter(?), reservior(?).
Hard to say what you need on the inside w/o actually seeing what's there. Also take into consideration the condition and age of the hoses that are there. Will still need PS pump either way. Does it look like there was only 1 PS pump being used? Do you have a steering cable going to the transom assembly? (determining what type of system you had) |
Looks like a Latham wing plate on your drives. I would try to get what your missing. Rams & hoses outside, Ps pump inside.Should have a cooler too but mabye thats gone as well. Look on the outside of your starboard engine or follow the hose from your seawater pump as that is typically where the cooler is located.You should have an acturator valve where your steering cable connects to your inner transom plate it connects back to your ps pump. post more pics good luck
| All times are GMT -5. The time now is 06:05 AM. |
