-   -   Can a 496HO Freeze Damaged Heat Exchanger be Repaired? (https://www.offshoreonly.com/forums/general-q/155428-can-496ho-freeze-damaged-heat-exchanger-repaired.html)
Rage 04-07-2007 02:30 PM
The area of freeze damage is a break/leak soemwhere between the sea water chamber and the antifreeze coolant chamber such that at high sea water pressure, sea water is pumped into the reservoir.
Does anyone know if a 2005 Merc 496HO heat exchanger that has been so damaged by sea water freezing can be repaired?
Anyone know specifically who has successfully repaired a freeze damaged heat exchanger for the 496HO?
Bawana 04-07-2007 02:48 PM
I have three that froze. I even cut one apart. It would be very costly to repair, if even, at all possible. Ended up getting new ones. If you do find someplace that will fix at a reasonable $, let me know. The problem with these are as follows; just draining system will not always get ALL the water out. I found out the hard way. I now either blow the system out with compressed air, and/or put anti freeze in the system for extended periods of storage for below freezing conditions.
Also, if someone can fix, will they stand behind the work?? Down time can be a pain, and waiting to get new ones takes time. And even people standing behind there work can also take time.
Rage 04-07-2007 05:07 PM
The one you cut appart, can you describe in as much detail as possible what, where and how severe the freeze damage is that occurs. Is it just a cracked solder joint at a union or gaping holes or what? If just a simple split solder joint a solder reflow could be an easy repair. But anything with a major gap that would require cut appart and reassembly would likely be prohibative. You do not still happen to have the damaged HE you cut up or any of the other two damaged units?
Payton 04-08-2007 06:05 AM
If it were mine, Id be glad it wasn't my block and order a new one.
Rage 04-08-2007 06:54 PM
Money to burn is nice.
oldandtired 04-08-2007 10:04 PM
I really don't think that you have much of a choice except to replace. The "disassembly" of the heat exchanger will be pretty destructive and will take a specialized craftsman several hours to tear it apart, find all of the leaks and solder/weld everything required. I doubt the work would come with a guarantee. You could always revert to raw water cooled.
Rene
LAKESIDE RESTORATIONS 04-09-2007 08:25 AM
Personally I would replace it. By the time you get done with repair you would have been better to replace it..
If you want to save some coin & Go new you can look them up on my web site under the Mercruiser parts look up application. All of our parts bought thru the site are discounted. They are also factory parts (not aftermarket).. :) Jamie
www.LakesideRestorations.com
Rage 04-09-2007 08:38 AM
If only soldered brass and copper it would seem that a radiator shop could acid "boil" off all the paint, desolder the pieces with a torch, solder repair the damage, reassemble and resolder together. If anything is truely welded then this approach would be a non starter. This is what I am trying to get a handle on. How is the HE put together and what is is made of? All brass/copper and soldered only or what? I would love to get a detailed drawing of the HE design from the manufacturer who ever that is.
If repair is not an option I will buy a new replacement to maintain the antifreeze protection for the engine. I just do not like throwing good money away. I can handle no "guarantee" if the repair cost is reasonable compared to buying new.
Rene
evaluex 04-09-2007 01:29 PM
Dustin @ Whipple recommands for the 496 upgrading to a Sen-Dure heat exchanger for superior cooling (5" ID ) which is a direct bolt on / replacement exchanger
They also may be able to fix your damaged one
Why not give them a call ? www.sen-dure.com
Let us know if something worked out
Rage 04-10-2007 11:53 AM
Sen-Dure #15006-1-5 (5"dia) $925 list, $693 street, 3 - 4 weeks delivery.
