trim tabs
Old 04-12-2007, 09:09 PM
Default trim tabs
Putting longer trim tabs on,Does it scurb some speed ?? Level with the bottom .Some boats have them up 3/4" from the bottom .Witch is better. V hull. Any help would be appreciated.
SCARAB98 is offline
Old 04-14-2007, 07:06 PM
Any help out there..
SCARAB98 is offline
Old 04-14-2007, 07:23 PM
Merc K planes directions say 3/4' above the bottom.
sschafee01@snet.net is offline
Old 04-15-2007, 07:15 AM
Dave M's Avatar
When my tabs are all the way up, there is no speed loss.
I never measured, but 3/4" sounds about right.
Dave M is offline
Old 04-15-2007, 07:32 PM
Tabs dowm but level with the bottom of the boat .Will it scrub some speed.With longer tabs.
SCARAB98 is offline
Old 04-15-2007, 08:24 PM
MOP
Mount them above the hull 3/4" at the hinge but a bit higher at the tips, high enough so they have no contact with the water at WOT.
MOP is offline
Old 04-18-2007, 08:48 PM
Tabs and full hyd steering? You must be buzzy .Lets see the pics of the tabs. Even if you mount them flush can't you pull them up past level?? Got mine repowder coated and back on.
turnerrd is offline
26sonic
Sonic
8
06-23-2009 09:14 PM
dloftis
Baja
8
03-12-2009 08:08 AM
paxtonsc
8
04-29-2007 12:21 AM
Hot Boat
17
03-31-2002 06:00 PM
dallas01
Baja
11
03-23-2002 10:33 AM
Quick Reply: trim tabs
