Preventing Valvefloat
I've been reading up alot on hyd roller cam profiles and valvefloat. I'm a little worried about my setup since I'm on the low end of recommened spring pressures.
355 SBC AFR 190 heads 224/230 .537/.511 112LSA hyd roller Morel vertical bar retrofit lifters Smith Bros .083" 1 piece pushrods Crane 1.6I and Lunati 1.52E widebody roller rockers Manley Stainless I and Inconnel E valves 2.02, 1.60 PTV clearance I .246", E .229" Isky #6105 dual w damper springs, 1.430" OD, 1.120" CB, 330lbs spring rate, Seat 135lbs, Open 315lbs @ 1.260", 1.812" IH. I'm breaking in the new drive so I have not had the motor WOT in the boat yet. On the dyno there was no float noticed but I feel under extended WOT runs on the water it might be different. With the 23p it's gonna max out in the 5600-6000rpm range. What do you guys think? Should I be allright or for saftey shim the spring pressure up? Thanks for the help! |
| All times are GMT -5. The time now is 03:57 PM. |
