-   -   Third battery (https://www.offshoreonly.com/forums/general-q/157238-third-battery.html)
MILD THUNDER 05-01-2007 08:54 PM
Third battery
I have two engines, and two battery switches. I just installed two stereo amps in my cabin today. I ran two 6 gauge wires from battery #1 in the bilge to the third battery i installed in the cabin closet. i would like the third battery to get charged from the alternator, but I dont want it to draw from battery #1. Now what?? Isolator?
bowtie 05-01-2007 09:00 PM
Isolator
ghittner 05-01-2007 09:28 PM
Yup, isolator.
offthefront 05-02-2007 06:08 AM
1 Attachment(s)
http://www.emarineinc.com/products/a...isolators.html
stevesxm 05-02-2007 06:36 AM
all you need is a 250 watt diode in the wire that ties the third battery into the other two. then the current will only flow in one direction. 5 bucks at radio shack or 10 bucks at any electronics store.
RedDog382 05-02-2007 07:01 AM
I have a extra Professional Mariner 3 pole battery isolator from my 382 Formula if you are interested.
MILD THUNDER 05-02-2007 05:19 PM
reddog, how much??
RedDog382 05-02-2007 05:38 PM
Originally Posted by MILD THUNDER (Post 2114315)
reddog, how much??
Looks just like the one in the diagram in Offthefront's post #4. Will get back to you on price later tonight.
mtgbiker 05-02-2007 08:55 PM
stevexsm, is that diode u.s.coast guard approved??
offthefront 05-02-2007 09:42 PM
I'm thinking a diode will let the battery charge but not disharge into the other batteries ? But it wont keep it from over charging ? Or can a Diode "shut off" at a specific Voltage ? I cant remember ....m
RedDog382 05-02-2007 10:23 PM
This is a Professional Mariner 2-70-3 model meaning 2 alternater, 70 amp, 3 battery application. Cost over $150.00 new. Will take $75 for it in box with instruction sheet.
Had a charging problem when I rigged my pre-owned 382 and thought it was the isolator. New one didn't fix the problem so I ended up with a spare.
Let me know if you are still interested.
