-   -   Where to ground Amplifiers? (https://www.offshoreonly.com/forums/general-q/157325-where-ground-amplifiers.html)
Jakkle5 05-02-2007 08:44 PM
Like the title says. Amps are under the seats in the middle of the boat. NO metal to be seen other than where the guages are grounded and even at that its only a small piece of flat stock.
speedygonzalez 05-02-2007 08:53 PM
it must go to batteries, and use same gauge wire as your + side.
Jakkle5 05-02-2007 09:19 PM
I've been told a few time doing that is incorrect and will fry the amps. Have you done it that way?
Nightlife1970 05-02-2007 09:28 PM
No it won't fry amps. Thats the best way to do it. Most performance boats are not built with metal frames like a car, so you have to go back to the battery. The best ground you can get in a car is to go back to the battery, same for a boat.
betitbig 05-02-2007 09:58 PM
I did exactly as I was told, I connected a wire to the ground.
I can't go to far from shore but the stereo sounds great...
BY U BOY 05-02-2007 10:06 PM
ground it to the engine that is the best way. also use a larger ground than the power.
IM4A2Z 05-02-2007 10:12 PM
Where do you think the batteries are grounded too?
Jakkle5 05-02-2007 10:13 PM
So engine or battery?
You beat me to it!
Thanks guys
BY U BOY 05-02-2007 10:25 PM
i know where the batts are grounded.it is better to ground to the engine than directly to the battery.
