Fuel pressure???, stock 500's
Built bigger C.I. out of 500 EFI's. Due to a fuel supply problem I want to add fuel pressure gauges to the boat. I want to use gaffrig electric gauges so they match everything else in the dash (biggest problem will be finding somewhere to mount them). What is the normal operating pressure of a 2002 500EFI and where would a sender be placed in the supply line. I assume after the top mount filter right before the fuel rail that supplies the injectors but is that correct?
Thanks, |
Well, the stock fuel pump will pressure up to 34 to 38 psi. As far as the gauge goes I have tapped into the fuel rail at the back and installed my sending units there. I'll have to look at one I have here to tell you exactly.
John |
| All times are GMT -5. The time now is 10:47 PM. |
