-   -   octane and timing (https://www.offshoreonly.com/forums/general-q/157738-octane-timing.html)
sleeper_dave 05-09-2007 03:10 PM
I just switched over to a 160° thermostat. I also switched to projected tip spark plugs.
Does anyone think these two changes will have an effect on how much timing I can safely run?
I kind of want to stay a couple steps away from the "edge". I can't afford to fix any major problems.
jdnca1 05-09-2007 03:11 PM
Originally Posted by rdoactive (Post 2122054)
Any ideas why only 28 degrees total on the 502?
Anyone?
Thought maybe because siamesed blocks didn't cool as well.
Gary
I ran an old carbed 502 mag at 35 degrees on 93 with never any problems...FYI Merc runs 36 degrees on 87 octane with their 500EFI's...
Griff 05-09-2007 03:16 PM
Originally Posted by Pat McPherson (Post 2122105)
Yes, the 454mag and 502mag have the same cam profile, but the initial timing of the two is 5° different.
On Gen V 454mags and 502mags, the cams are exactly the same and have the same Merc part number 431-9830.
The stock ignition module for the 502 mag shows it as a V8-20R which really makes no sense. That module does not make full advance until about 5250rpms. Unless he is running at 5250rpms, he's really running even less total timing.
The 454mag uses a V8-24 which is at full advance at 3750rpms.
jdnca1 05-09-2007 03:19 PM
V6 module is best to run on stock system....timing is all in way sooner...like 3000. (can't remember for sure)
sleeper_dave 05-09-2007 03:26 PM
I checked the timing on my 502 running full tilt across the lake and it did in fact have the full 20° of advance in before 5000 RPM's. I do believe the published curve says it doesn't get it in that fast, but according to my timing light, it did.
kaama82 05-09-2007 05:31 PM
My motors (496 Gen IV) 10 to 1, Canfield alum heads, run 92 to 93, 36 total. No problems at all...
