what SBC head to run?
I have a SBC in my boat, it is a Chris Craft 245 Limited, I have a balanced and forged roller shortblock, now with 9.5:1 with 64 CC heads, GM cam ZZ( (112LCA INT.212 EXH .226 Lift is .483/.520 I have dart sprtsman200 heads with a 200CC intake runner, performer intake, and 650 holley, I am thinking my heads are killing the torque, I got them cheap so I thought I would try them, I was thinking going with a 170-180CC intake runner, does that sound good with the cam I have?
what kind of small block combos are people running? |
Here's mine....
355ci Eagle 4340 3.480" crank, forged I beams and TRW L2304 forged pistons, rotating assembly balanced very well. 1980-85 4 bolt block align honed, decked .020", bored .030" Melling M55A HO oil pump, Moroso 7qt oil pan w windge tray. Edelbrock Performer RPM intake AFR 190cc aluminum heads 74cc 10.0-1 SCR, .039 quench, 2.02I, 1.60E, Flow 261cfm @ .500 with strong midlift flow numbers Morel Retrofit Roller lifters 224/230 .537/.511 112LSA 110ICL roller cam Crane 1.6 roller rockers on I, Lunati 1.52 rollers on E Holley 4150 750CFM carb Smith Bros .083" wall 1 piece pushrods Glenwood Marine HP aluminum manifolds w FastGlass 4" stainless smooth long risers that are 16" long. Almost a dry system as water hits the exhaust 3" before it leaves the tips. No Reversion The 200cc's ports you currently have are a tad big for a 350. A high velocity 180cc port would work better but that's alot of $$ for what gain I cannot say. Keeping the larger port is just going to need to be spun up higher. 5500+ rpms. I like the AFR 190cc's, they flow great and make awesome power. The new Eliminators are even better than mine. http://img520.imageshack.us/img520/2...s107cm1.th.jpg http://img258.imageshack.us/img258/5...1075jy2.th.jpg http://img258.imageshack.us/img258/7...1077oi8.th.jpg |
Originally Posted by Ryan00TJ
(Post 2124889)
Here's mine....
I have AFR 180 Elimators. I purchased these heads at the recomendation of RM Builder. He is also grinding a cam to match the combo. The new 180 eliminators outlflow the old 190s, the small port should produce high velocity and great torque. I will tell you how it turns out once I get it together. They are going on a 383 w/ 6inch rods.
383 with:
Dart iron Eagle 200, 72cc. Forged flat tops crane 284H (228@050), .480 lift w /1.5 rockers 1.6 comp cams stainless rollers Brodix dual plane bG 750 mech secondaries 10.2:1 comp Rhodes lifters Revolution exhaust. This motor pulls better than a 454 Mag. Seat o' pants dyno (semi educated guess is a bit above 400 HP in boat. Instead of spending money on new heads, get that thing stroked! Then the heads would be perfect. |
Originally Posted by jmherbert
(Post 2125183)
383 with:
(Post 2124889)
Here's mine....
Your fine where your at, save your pennies for a stroker kit!:D
Originally Posted by mrhorsepower1
(Post 2125301)
GM Performance Bowties work awesome on my 383's!
I have the Edelbrock E-tec 200's on my Procharged 383 and they work very well.
Originally Posted by 245 limited
(Post 2124946)
Looks like a good combo, what is it in, how does it run?
Alpha 1 w nosecone, 1.5" raised X dimension, 23p labbed cleaver, I've finally got the new drive broken in and opened it up quite a bit this weekend. I've got the jetting right 72P, 76S and I can't be more thrilled with how fast it is. Full tank 50gal, 3 people 69-70gps @ 5300rpms 1/4 tank, 2 people, 74gps @ 5400rpms Near empty, just me, 76gps @ 5500rpms http://img521.imageshack.us/img521/9...hot2ls6.th.jpg http://img453.imageshack.us/img453/4...y071cx1.th.jpg http://img168.imageshack.us/img168/5...wfo2js8.th.jpg My previous 360ci SBC had the same AFR heads as this engine. I had them redone for the new build as they had around 500hrs on them. Motor was 9.2-1 SCR It had a hyd flat tappet 224/224 .465/.465 114+5, Performer RPM, 1.5 roller rockers, Holley 750 dbl pump, Glenwood HP manifolds, FastGlass short risers, Jasper Marine shortblock, Engine ran great and was powerful but this new build is above and beyond. Fastest the 360 ran was 70gps and that was with a near empty tank, 1 person and alot of weight out, same 23p cleaver. |
Nice!!
| All times are GMT -5. The time now is 11:17 AM. |
