500EFI - .040 Vs .035 Plug Gap
I Put New Extended Tip Plugs (R43TS VS R43T) And Had A Brain Fart, Gapped The Plugs At .040 Instead Of .035. Do You Think It Will Be Fine Or Should I Pull All The Plugs And Regap. Thanks For All Your Help.
The Boat Is Going In Tuesday Morning - Finally!!! |
you will be ok at .040 where people get into trouble is opening the gap up to try and pick up a few more h.p.'s and they have old spark plug wires and they start misfiring. the stock coil has enough voltage to fire a wider gap than stock.
my 2 cents anyway!!!:D |
They should be fine for a while. Eventually they will burn the tips harder and you'll have to change the plugs sooner than before.
John:D |
| All times are GMT -5. The time now is 11:58 AM. |
